Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Alpha 1 outdrive stand
  • Alpha 1 outdrive stand
    Is there a reason I need to build an outdrive stand for my outdrive when I pull it? any reason I cant just lay it on its side?
    Re: Alpha 1 outdrive stand
    Won't hurt a thing to lay them down.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      Ayuh,... They just take up less floor space stood up,...
      Bein' un-vented, you can stand 'em upside-down if ya like....
      • #4
        Laying on its side just makes it a bit harder to work on...
        xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
        The world takes on a whole new perspective when viewed from 100’ below.
        1972 Bertram ‘Bahia Mar’ 20
        2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
        (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
        • #5
          I use a Black & Decker "Workmate" bench. With the prop removed, the whole unit fits nicely.
          I've got a second one which I use if I seperate the upper, again, being adjustable it works well to hold/work on.
          "There never was a great man yet who spent all his life inland." Hermann Melville
          1991 Celebrity 230/5.7/Alpha One..."BarbMarie"
          • #6
            when I pull my 5.7 ltr engine will it mount up to an engine stand? Id really like to put it on a stand to make it easier to work on. Change plugs/ touch up the paint etc...
            • #7
              It will bolt to a stand if you remove the flywheel cover, coupler and flywheel.
              Don S.
              • #8
                Thanks Don! thats what I needed to know, appreciate it!
