...mercruiser 888 ford 302...
haul has the right idea regarding parts.
I want to caution you that you are mixing engine names, and what you typed doesn't exist. The 302 Ford was called the 188 when used by Mercruiser. An 888 is a 305 Chevy used by Mercruiser. That may have been part of you search problem?
Nope,.... The 888 is a Ford, the Chevy 305 was the 898...
Or you can ditch the chain and go with a gear drive.
Summit Racing Street & Strip? Gear Drives SUM-G6711 - SummitRacing.com
Don't need all the other stuff; but like a chain, gears don't stretch. Do it once and be done with it.
