Last season my 2004 19ft Stingray LS developed an issue where the starter wouldnt turn over until after a 3 or 4 second delay from when I turned the key. Sometimes I had to jiggle the key a bit to get it to start. I never got stranded, but there were a few times where I was out on the lake and my fiance and I got pretty nervous. Not a great feeling...
I did some research and have come to the conclusion that the most likely culprit for this is a worn out ignition switch. Problem is...i have no idea what ignition switch I need. The boat's all wrapped up and I would like to be able to order the correct part so I can change it over when it's time to wake her from her slumber....
Anyone have any ideas on how I can track down the correct part?
