Took the boat out last week. Started up fine... stopped engine outside the harbor for lunch. Wouldn't start!!! The starter kind of turned but only for a split second... sort of a 'chunk' sound then nothing.
Boat is 1991 Sea Ray 2250 with Mercruiser 454 / Bravo I drive.
Is this corroded battery cable connector likely to be the cause? I checked the battery voltage, both batteries are over 13 volts (I keep them on a trickle charger). Both cables look like the one in the picture...
I am going to replace the cables of course, I am interested in opinions about whether the thumbscrew style is good, or the clamp style that is used on cars? Seems to me the clamp style would be better...
Thanks for your opinions, you have helped me in the past!
