Smartcraft question
agallant80
Don't know if this is posted in the correct section or not but does anyone know if I can just plug a smartcraft gauge in to my 2013 5.0mpi?
agallant80
Re: Smartcraft question
I noticed behind my dash that there was a harness that was not plugged in to anyting. I will take a photo of it the next time I am out. If the harness is there is all I need to do is plug in a smartcraft gauge and it will work or does it require some type of ECU upgrade?
tazrig
I believe it is all ready programmed into your ECM.
Don S
Your PCM and wiring harness is set up for it, but you will need the CAN harness and other items shown in the instruction sheet Fun Times posted. Page 9 of those instructions give you the PN. Make absolutely sure to put the term. resistors as shown, and get caps for all unused ports on the junction box.
