bigblackcat
- Mar 8, 2012
- 23
Going to pull a 160 mercruiser out of a 68 seaswirl. Owner said it has oil in the water. Said that when he was out on the lake noticed the temp gauge getting hot. He shut the engine off and check the oil level; found to be milk shaked. He also reported that it was not winterized after the prior season.
My question is how could I check if its
a blown head gasket, bad manifold or riser, and finally internal cracked block?
