I have no power what so ever on this motor. I just bought a formula Thunderbird 1977 and put a rebuilt carb, new fuel pump timing gears and chain and still have the same problem. When you give it throttle it bogs down.
I have set the timing at 10 degrees and still has no change.
I have tested all cylinders and they are all around 190 lbs.
