glennj3
- Sep 6, 2011
- 380
Finally got around to pulling the lower unit apart, decided to check the water impeller while it is off. Needed replacing of course after only 4 times in the water last summer.
From a previous thread, my shifter stopped going into reverse (would not move very much backwards). I know the shifter needs to be in forward then join up the lower unit with the water connecting pipe in place. Problem is my lower unit is in forward if I am not holding it in neutral. I am not sure of the sequence of putting her back together.
I don't know the name of all the little parts up there but I can explain as best I can. I have the shifter shaft with the star teeth in the upper outdrive, it joins into the shifter in the bottom part. But if the shift shaft is not in the correct position when joining up with the shifter cable in the outdrive, the shift handle will not work correctly.
So do I leave the lower unit in forward, shift handle in forward, start putting it together with the upper, position the shift shaft into the slot with the shifter, then slide it into the shifter coming from lower unit?
Tighten everything up then check the for correct gear adjustment?
Sorry for the poor ID of parts.
Glenn
Glenn
