1992 3.0 exhaust manifold
brettdavis
I have recently purchaced a bowrider with a 3.0 mercruiser. How do I know if the exhaust manifold needs replacing. According to the original owner, the boat was primarily use in fresh water with ocational trips to the gulf. The boat only has 80hrs but is a 92. What is your advice.
Thanks.
Re: 1992 3.0 exhaust manifold
Thanks.
Ayuh,.... Pull the riser off the manifold, 'n inspect the gasket surfaces on each piece....
After ya Clean 'em to shiny metal...
