frankttaylor
- Apr 3, 2012
- 100
All,
Well today I finally attepted to finish winterizing my boat. I followed the owners manual that came with the boat and it states to:
3. Make sure drive shaft housing water drain holes and gear housing water drain holes are open.
The lower hole on outdrive appears to be open but the upper one seems to be closed. How do I open? I cannot locate in operation and maintenance manual.
Here are my specs.
1990 Bluewater
3.7 Liter
Engine# OC768011
Thank you!
Here are my specs.
1990 Bluewater
3.7 Liter
Engine# OC768011
Thank you!
