Bucketlist
- Nov 10, 2012
- 3
I have a 1998 502 mag mpi engine with about 500 hrs on it. The engine is completely stock and serviced regularly by the same reputable shop. It has been used almost exclusively in fresh water lakes. The engine exhibits intermittent performance issues. When the problem happens the engine is down on power during throttle settings from about 80 percent to WOT AND the air temperatures are always above 95 degrees. When the engine starts to exhibit power loss it feels like it is not getting adequate fuel supply. The constant clue to this problem is air temps above 95. When the engine loses power the engine does not seem to be missing or surging. It just feels like it loses about 100 hp when it happens. Problem occurs the same with either full or near empty fuel tank, with fresh 87 or 91 octane gas purchased from many different fuel stations. This problem has existed for at least the last 200 hrs of use and has gradually gotten worse and more severe. When engine starts to lose power i can only get between 4100 to 4400 RPM at WOT. When the engine is running properly i can get 4900 to 5100 RPM.
When air temps are below 95 this problem generally does not occur. Also, when the engine is first started cold, the engine performance is perfect and as the air temps increase during the day the problem starts to intermittently occur. Engine idles good.
Inline fuel and water separating fuel filters have been replaced, gas tank venting system checked and is ok, seawater and circulation pumps replaced, engine water flow checked and ok, compression and leak down tests normal for hours on engine. Plugs and plug wires have been replaced at 400 hrs. Bilge area has adequate exterior air venting in and out.
