Hi all, first post here. i have ordered and recieved a new trim hose for my 1969 mercuiser 120hp i/o. trim stopped working turned out the old hose was all coroded and leaking oil. question is, how do i go about replacing the old hose? i have removed the old one (to make sure i got the correct one ordered. all of the fluid that was in there is gone, and might be water in there? i assume that first i install the new one, but then what? what are the steps to re-filling the hydraulic fluid, and what type of fluid do i use, do i have to use a special tilt trim fluid from the marina parts dept. or can i use some type of auto tranny fluid? i am mostly confused about how to bleed out the air. any advise would be greatly appreciated.
