I'm looking for a wiring diagram for the engine on a 1996 4.3., SN: 0F821477.
My fuel pump suddenly doesn't work. I am in the process of doing a compression leakage test and I pulled the valve covers. To do this I had to pull the shift bracket and disconnect shift interrupter switch, as well as the remote stern drive lube tank, and sensor. Additionally I pulled number one spark plug and the distributor cap. I need to warm it up to operating temp before I begin the leak-down test so I'm trying to start it to do so. I put the dist cap back on and plug wire number one back. When I attempted to start it is wasn't getting fuel. I can get it to run with carb cleaner sprayed into the carb.
I cannot hear the electric fuel pump running, therefore I'm looking for diagrams so I can figure out what to look for in this system. I imagine the ignition control module controls the fuel pump, and I may have a blown fuse or something, but that's why I need the diagram. I didn't see anything useful in manual 18.
Thanks,
Chris
Thanks,
Chris
