I've got a '97 Mercruiser 5.7 with an Alpha 1. It has power steering which works fine. I have to add fluid after every outing. I've probably used about 3/4 quart in 3 outings.
I don't see any leaks around the pump, hoses, or fittings. I never see any oil in the bilge or any oil film in the water. I can't figure out where the leak is.
Do I have a power steering cooler? How do I test it? Is it hard to replace?
Thanks,
Thanks,
