Bill Rod 71
- Oct 9, 2012
- 9
Hey Everyone,
I'm new to the forum and new to owning a boat.
This is what i got going on. I bought a 1993 18 ft Celebrity 4.3 Mercruiser w/ 4bbl. I haven't had the boat on the water yet have only owned for a few weeks. I was running the boat with the ears on and it started to overheat. So i pulled the thermo which was in bad shape. While I had the thermo out I noticed a hole in the timing chain cover. Pulled the water pump to change the cover and noticed the water pump (recirc) had been leaking. Yea I know! So far owning a boat has been great. LOL. Luckily I don't mind turning some wrenches. So I have installed a new water pump, timing chain cover, and thermo w/new sleeve and rubber o-ring. Boat is running fine but temperature gauge is getting to 225 degree before thermo opens and then gauge goes back down to 150 degree. Then repeats. The risers are getting pretty warm/hot. Not so hot that I can't touch them but hot enough i wouldn't leave my hand on them long. Plenty of warm water coming from bottom of out drive so I assume the water is circulating through the engine. Boat had been sitting for 6 months or so before I purchased. I'm thinking maybe the gauge or sending unit is not working properly but just wanted to get some opinions first. Thanks
