PowerAddict
- Aug 8, 2007
- 418
This started after I did a compression test.
There appears to be no power at the coil. I cannot figure out why? However, if I pull the main wire off of the coil and leave it loose on top, I can see spark when I crank it....what?!
I have the troubleshooting diagram, and it says to check harness and such if there's no voltage at the coil, no step after that.
There is a kill switch, but that just cuts power, If I put 12 volts from the battery to the coil, it still doesn't start.
Any ideas?
Any ideas?
