Hi guys, I thought I'd start a new thread dedicated to the cause.
After finally getting my 470 on the water, she overheated.
Hit 225 after 20 mins or less.
I cut the engine, let her cool and headed to shore - did not blister paint or get too hot.
The exhaust manifold and riser has been replaced for a new one.
The 3 inch HE has been replaced for a second hand 4 inch.
The exchanger has been rodded and is or was clear.
The impeller has been checked and looks good (was changed 2 months ago)
The flow of water from the transom outlets is low, like a spray.
Local mech said blockage or headgasket blowing into water.
Any troubleshooting steps greatly appreciated.
Where should I start ? replace the impeller and housing (housing was not changed last time but engineer said it was ok)
Many thanks in advance.
Never ending story this engine.
EDIT - For info she seems to overheat in the 3000 rpm and above range, allow to cool she will cruise at low revs at 175 degrees.
Lots of water from the prop when on muffs, only spray from the transom oulet.
Also when leg is in a bucket - noticably less water from outlet than when on muffs - but still nothing compared to my friends alpha 1 outlets...his gush, mine spray.
Hope that helps nail it down.
Ron.
Ron.
