I need some assistance on my 96 4.3 setup.
Engine SN: 0F821477
Stern Unit PN: 5010181JP
Stern Model No: 6010000JS
SN: 0F678198
My PS is not working. In my attempt at troubleshooting I broke off the pressure hose fitting at the actuator, and will likely break off the return hose when I try to remove it. Rust has gotten them both. PB blaster soaking a day before removal attempt did not help.
I have found a fellow who has a new pressure and return hose, as well as a NOS PS actuator, which I may or may not need. He is selling the actuator for 250, which is much less than list, and my PN, as far as I can tell, is no longer available, so I am thinking about getting it if I drive all the way out there to buy the PS hoses. It appears that the PS hoses are also no longer available.
I have seen a pic of the actuator and it does look like what I currently have, but what I currently have does not match the picture in the parts diagram on the Mercury site.
Part numbers I *think* I need:
Actuator: 89645A33
Pressure hose: 96790
Return Hose: 9884339
Parts I'm looking at buying:
Pressure Hose: 32-8062216
Return: 32-80622142
Actuator: 806034A1
Hoses for 50 bucks each, and actuator for 250.
Can anyone say if these parts, through succession chain or whatever, will work on my boat?
I do have a PS cooler across the back of the engine. Attached is a pic of my current actuator.
Thanks,
Chris
Engine SN: 0F821477
SN: 0F678198
Actuator: 89645A33
Return: 32-80622142
Actuator: 806034A1
Thanks,
Chris
