I have a 1979 MC 1 transom plate and outdrive. I have installed a 1995 Alpha 350 engine. I have the wiring diagram for the thunderbolt 4 ignition. I see that the interrupter switch basically connects ground to the coil, when the y plate is activated. When I do a continuity test by touching one end of tester to black lead, the other to brown, I do not get continuity when the y plate is pushed........does this show my switch is bad, or am I missing something?
