mitchell2345
- Jun 25, 2011
- 78
What I learned.....
These instructions are pretty good but they fail to mention the following:
View attachment A1G2 Impeller Replace.pdf
1. Before removing the lower end remove the speedo tube. After you remove the front zinc it can be unplugged. Its behind the nut you must remove. It may have a twist and pull (old style, its white) or a push button and pull that is black. If you dont do this you break it like I did.
2. There is a filler wall that slides into the upper section that may fall out...it needs to go back in the grooves. If yours falls out like mine did it may end up in the bottom of the exaust path. Remove the prop/zinc and push it out from there.
Good Luck!
Mitchell
Good Luck!
Mitchell
