Re: Trim meter
If its a mercrusier, your trim sender or the wiring to it is most likey suspect. <br /><br />Replacing the sender requires removal of u-joint bellows. <br /><br />Might be a good idea to hold off on it until you do all of the bellows. Replacing the bellows should be an every 3-5 year thing if your boat is in a slip.
