Duncan McCallum
- Aug 27, 2012
- 1
I noticed this summer that my exhaust bellow is cracked and had planned to change it in the fall when I winterize.
Recently I had to drop the gear housing to get the skegg welded after hitting an unmarked shoal. Then I notice two things:
1. A plastic cup like shroud around the water pipe going up the water pump is melted:
2. As is something made out of to semi-circle pices of metal and rubber in between. This last picece fell out of the exhaust manifold above the water pump. The white plastic water dam is fine and in place.
Any idea what these are?
