500dollar744ti
- Jul 23, 2012
- 691
well, i know you can't tell me what broke but you can guess. 1990 350 magnum alpha 1, gen 1, 270hp, 14.75 x 20p solas titan SS prop. i think i was overpropped for the load but my 17p spun a hub the day before.
was out in the ocean on a nice day, pulling a tuber right along the coast about 200 yards away from the beach. boat loaded with 6 people at about 20mph. just running along nicely, i'm watching in front, my spotter right next to me watching the tuber.
lost all forward movement, engine revved and i yanked it back to idle. i shut the motor down and made some inspections, didn't see anything visually amiss, so started it back up and found i had no forward or reverse.
i let it idle for a bit to see if the temp was going up and it was so i shut it down. i jumped in the water with it in forward gear and i was able to turn the prop both ways.
i haven't had this boat long and i didn't get a boatUS membership yet for towing, be sure i'll have one before i go out again. was very lucky to be able to call up a neighbor and have him come out to me and tow me to the launch so i could pull the boat out.
i pulled the drive off today, found the problem to be between the input shaft and the prop shaft. thank goodness it's not an engine coupler.
with the outdrive off, i can put it in gear manually and lock the prop but it still spins independently of the upper input shaft.
any guesses where it broke? my prediction is the long shaft that sticks out of the lower unit, it looked like a pretty wimpy thing to me last time i had it apart.
if it is the lower unit, are there any options for me as like an upgrade with something beefy-er? i'm a car guy and if something breaks on my race car i generally try to not just fix it but also make it better so it won't happen again.
i can't swap a bravo without pulling the motor, correct?
i'm going to make myself a nice meal and then after dinner i might go split the outdrive to find the broken stuff.
iboats is awesome by the way!
