cheburashka
- May 28, 2005
- 715
'97 Maxxum. I've found four drain plugs so far--one on each side of the block and one one each exhaust manifold. I've traced the hose that goes back from the four-input manifold on top of the front of the engine back to the steering rack and found that it goes past the rack, makes an "S" turn, and connects to a fitting that appears to go through the hull. The problem I'm having is that if I blow into that hose, I can hear water bubbling. The other three are clear.
Did all steering rack coolers have drain plugs? If so, where should I be looking?
And yes, I checked the manual. It says "have an authorized dealer winterize your boat" and says nothing about where the plugs are located.
Thanks
Thanks
