Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Boat takes off and the blows fuse
  • Boat takes off and the blows fuse
    I just bought a 22' scarab with a 7.4L Mercruiser MPI. The boat had fuel problems before, the electronic fuel pump filter was clogged up. I got that problem fixed, and now I have another problem, so I figured I would try this forum again because it was so helpful the first time. Anyway, the boat gets up on plain and runs for a short time and then all of a sudden, the thing just shuts down, like someone had turned the key off and won't restart, I was able to trace out that the ignition fuse was blown, so I changed it, tried it again, same thing. Put it on the trailer, hook some water up to it and it seems to run fine. I have had to be towed in 2 times in a row because of this problem. If anybody has any idea of why the fuse keeps blowing, please help me. It is a 20 amp fuse, and the fuse panel says it is supposed to be a 20 amp fuse for that switch. Any pointers would be appreciated.
    Re: Boat takes off and the blows fuse
    I'm Not fimilar with Your motor,....But,...What Circuit is protected by the Fuse you're Replacing,.??...There's a Dead Short in it Somewhere......Finding it probably Won't be Easy,.... I'd try the Shake, Wiggle,+ Pull Tests 1st......
    • #3
      My bayliner did exactly the same thing, could idle all day and when on plane, fuse would blow, found shorted wire rubbed on bolt head and bouncing around would blow fuse.
      • #4
        Thanks for all of the pointers, There is an hour gauge in the engine compartment, and it comes on when you turn the key on. Anyway, the connectors for that had come off and were laying up against the engine, I put new connectors, and away we went... Now boat takes off and hauls, not blows fuse, thanks for all the help!
