Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
ford 351 hard to start when hot.
  • ford 351 hard to start when hot.
    hi guys im currently looking at buying a 93 mastercraft prostar with a ford v8, current owner has told me that it can get hard to start when hot and has placed some rockwool around the distributer to prevent this happening, just wondering if this is a common problem or something more sinister...have seen it running and all seems well but would like to be sure before handing the cash over...
    Re: ford 351 hard to start when hot.
    I Don't Know about Sinister,...........But there's No Doubt a Cause of the Issue.......... I Also Don't Know if it should be a Deal Breaker,.......But it Should be Investigated.........If you Still like it,.. Use it as a Bargaining Chip.......
    • #3
      Starter old and the heat is making it weak...Vapor lock (fuel line against engine block)...what else Bondo???
      • #4
        BAtteries overcharging and getting too hot, then when you try to restart the batteries are still trying to recover from the overcharge...
        • #5
          I think the most common cause is timed a little to fast and when try to start cylinder fires before reaches TDC. This makes it sound like a dead battery that will barely turn the motor.Slow the timing 1 degree and it will fire right up or in some cases getting a new set of centrifical advance springs for the distrubuter is all that is needed.
          Have some fun and enjoy the Great Outdoors.
          Love to fish out of Bodega Bay, California.
          • #6
            Izzit crankin slow,or just won't fire?
            • #7
              Don't think it is a major issue....Answer Walt's question for a better reply....JK
              Disclaimer!: In my inexpert opinion......
              • #8
                have only had it going with hose attachment in the yard but it started first time from cold, going to get a proper splash in it on Saturday, the current owner just made comment that it can get hard to start when running for a long time i.e. good afternoons skiing but that it fires right up if left for a couple of minutes to cool...kinda sounds like vapour lock to me but open to suggestions , thanks guys.
                • #9
                  Fuel percolation? Try running it with the engine cover off. It might be as simple as under-cowl heat. The fix may be more vents, wrap some aluminum foil around metal fuel lines leaving lots of wrinkles in it to serve as a heat sink. Run the blowers after shut down to exhaust heat. Lots of inexpensive things to try to isolate the problem. Bad condenser that acts up when hot.
                  • #10
                    seems more of an elecrrical problem ,wouldnt start after a good run, checked the coli lead for spark and had no spark at all...opened up distributer cap all seemed well, tapped the coil a few times with a screwdriver and it started right up...dodgy coil?? or something in distributer??
                    • #11
                      Just a thought. It could be loss of compression when hot which is not a good sign.
                      • #12
                        Dump the coil.
                        Watch this space......................
                        • #13
                          Dump the coil.
                          • #14
                            just bought a new coil today ..will try it at the week end thanks guys will let you know...
                            • #15
                              tried the coil guys....still have the same problem...gave it a really good run today and after about 20 mins it started to miss a bit pulled it into the mooring and it wouldnt start again i left it sit for about 15 to 20 mins and it fired up straight away..any ideas would be great thanks..!!
