I am the second owner. The first owner stored the boat most of the time. My oil pressure on start up is about 15-20 psi and at cruising speed is about 45 psi. After the engine is hot, and I go to idle, the oil pressure drops to 4-5 psi, and the alarm goes off. Increasing the rpms to 1000 brings the pressure back up to 10-15 and the alarm stops.
All pressures are measured by mechanical guage. The engine performance specs say minimum at idle is 4 psi, and I am at or just above minimum, but the alarm is disconcerting.
Per the computer, the engine has 126 hours on it, and NO CODES are recorded, despite the alrm having sounded many times. I had the engine checked my a Mercruiser service facility before purchase, with no problems reported (they did not see any low oil pressure, as the engine has to be run up to fully hot before it happens). What are your thoughts?
