prc03sx195
- Nov 3, 2007
- 151
While I was pulling my boat out of the water someone mentioned I was missing an anode on the flat portion of the outdrive (right above where the prop spins). There is a round aluminum disc about 3" dia. with a threaded hole in the center. He said that the anode screwes into this. There is a rubber plug on the topside for a ratchet extension to go into but I think that threaded hole is for the bolt to hold it in. I was thinking that was the anode, the round circular disc.
This may be confusing unless you can visualize what I am describing but maybe someone can steer me in the right direction. Am I missing something here or am I all set? Thanks
This is a 2003 I/O Mercruiser.
paul
paul
