Re: Mercruiser outdrive: pump runs but won't lower
Well, I disconnected the lines, and the pump is pumping good to the cylinders. I jumped up and down on the outdrive while running the pump in the down setting, but still nothing happened. I used a block of wood and hammer against the end of the cylinders to break anything loose, and still nothing. Any suggestions? Is there anyway to manually lower the outdrive? Thanks.
