Re: 120 mercruiser outdrive lower unit install
Just had to replace the water impeller on my 120 mercruiser alpha one outdrive...now start the boat and when I shift it into forward or reverse the engine dies...guess I didn't get the shift switch back right???...anyone guide me through the steps to fix this..thanks!!
Ayuh,.... Welcome Aboard,... Drop the lower again,... Make Sure Everything is in Forward,...
HOLD the lower in Forward, 'n reassemble....
(I use a bungee to hold tension on the propshaft)
The lower slipped outa gear as you were puttin' it together,.....
