Familytime10
- Mar 5, 2010
- 2
Hi,
Just got this boat and saw your response....I am unable to find a way to start a new thread. I have a 1992 magnum with a 4.3 mercruiser that I just bought recently and then repaired the exhaust manifolds from a bad epoxy job. After starting it and running it for 10 seconds, it busted the power steering return hose as it enters a temperature regulator tube that has engine water passing through under the Left exaust manifold. I thought I damaged it at first considering placement of it but then restarted it and had the aprox 1/2 soft black rubber hose in my hand when it swelled a lot in my hand and ripped some more spewing out ATF. what is likely here? I will replace the whose tomorrow just in case and buy water ears for the engine so I may run it for more than 15 seconds. c775-722-5520
MODEL MDM 4.3 1992
ENGINE S# 00811822
TRANSOM S# 0D745979
DRIVE S# 0D731326
MODEL MDM 4.3 1992
ENGINE S# 00811822
TRANSOM S# 0D745979
DRIVE S# 0D731326
