redgoat
- May 23, 2010
- 102
The timing tab on my 1967 Mercruiser 153 cu.in 4cyl engine has a timing tab that just has marks but no numbers to indicate degrees before and after TDC. The tab was painted over in the factory and I have somewhat had to guess all these years as to where the factory specs of 8* BTDC is located. Could someone attach some numbers to the attached photo to identify the various degrees. It would be equally fantastic if another forum reader would verify their correctness. Thanks in advance.
