Re: Engine Cuts Out
Engine completely cut out several times, just like shutting the ignition off. Happened at varying RPM and restarted each time. Seemed less likely to happen at lower RPM.
After doing what I could myself and with no resolve except for discovering the alarm beeper disconnected, I took the boat to the local Merc Dealer. They downloaded codes [94- pilot pressure circuit low; 75- fuel level circuit level high; 119- steering circuit low; 130- twin sensor high]. They determined these to be "soft" codes and would not result with engine shutdown. Their experience led to fuel; they removed the fuel filter and discovered 40/60 water/fuel; a new filter was installed and the engine restarted and codes erased. The boat has a new fuel pump.
I took boat home and completely drained and swabbed the fuel tank and added new fuel. A 1/2hr test run, boat ran well. Next day straight run for about 1.5hrs, no problem,beached for about 1hr, 5 minutes running after restarting the alarm sounded, 2 consecutive beeps every minute or so, engine cut out about 10 minutes later (running around 3000RPM); restarted and engine cut out 2 more times as I limped home; got home and removed the fuel filter; no water; reinstalled the filter and went for 15 minute run; drifted for about 1/2hr restarted and ran another 10 minutes or so OK again.
I am sure the issue is not resolved. It is terribly expensive to again have codes read at $125 plus $70/hr for trouble shooting. I am considering removing the fuel rail to rule out water there........???????
