VT Mercruiser
- Jul 30, 2012
- 2
120 2.5L 1985
Symptom: Motor almost dies on slow acceleration between 1200-1500 Rpm, then will pick up and run great up to 3200-3300 rpm. Idles fine and runs fine up to failure rpm. Pump the throttle and it shoots out of the water and planes almost instantly. Everybody complains about the "merc bog" on hard accelleration, this boat is opposite... ?!
What has been done: Replaced Plugs, Wires, Cap, rotor, Cleaned distro flyweights and springs, Rebuilt carburetor and set float height and drop to merc specs. Cleaned spark arrestor, replaced both fuel filters. Checked timing base at idle and advance under load at "wot". Fuel flow and pressure is good from pump. Fresh fuel and additive. Replaced all bellows, manifold and riser gaskets. Boat barely ran when purchased so we are slowly improving, just not there yet.
According to specs boat should achieve 4200-4500 rpm at WOT. Boat is a 1985 Regal 185 with a 15x15 aluminum prop in good condition. From everything I have read that small pitch prop I should be revving out.
On the drawing board, compression test, gravity fuel to carb?
Anybody have any ideas?
