Greetings! Need help with my 1986 5.7 Mercruiser / Sea Ray 22? Monaco. At idle, with no accessories on, blower, etc, the voltage at the battery is 12.8 volts. Applying power, (accelerating), the voltage at the battery and panel gage, drops and stays at 11.8 volts. I had the (Mando AR-150) alternator tested - results OK. The company who performed the test, let me borrow a re-built alternator which was tested before I left the shop. I installed the loaner and had the same results. Had the battery tested by two shops and was OK. Ideas would certainly be appreciated!
