I have a 93 malibu with 2006 quicksilver repowered magnum. I think I have loose wiring harness as it wont start (nothing on turning ignition) unless I jiggle with wiring harness at back of engine. I discovered this after replacing the alternator and the 50 amp circuit breaker. both were getting old as breaker would not push in anymore. But that wasnt the problem!
So it starts and there is no audible warning sound, but the light on the panel is telling me that there is no oil pressure and warning light stays on with increased idel.
Wondering if it is the sensor or sending unit? I cant believe it would be the oil pump and isnt that in the bottom of the pan? I am dreading that could be the problem sinc the engine would need removal to get at pan.
how can i see if oil pressure gauge is wrong? take out the sensor?
thanks
I am trying to salvage the boating season!
thanks
