Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Use sealant on carburetor gasket?
  • Use sealant on carburetor gasket?
    Am I supposed to use a gasket sealer (Perfect Seal?) on the gasket and mating surfaces when re-attaching the carburetor to the manifold on my Mercruiser 3.0 engine?Thank you,Barrett
    Re: Use sealant on carburetor gasket?
    No
    • #3
      He's right.
      sigpicIf it were easy, any Caveman could do it.
      • #4
        no never on carb gaskets
        • #5
          Just out of curiosity, why never on carb gaskets?
          1980 Sylvan Aluminum 18' Sportster I/O - Mercruiser 140, Honda 7.5 Kicker, Bennett M120 Tabs
          1974 Glastron V-179, Mercruiser 140
          1984 16.5ft. Alumarine Sealark side console with 82 Merc 50
          Manitoba, Canada
          • #6
            marc c, theres no need. The seal is fine, as the carb sucks air through that big hole on top,and it will not need to look elsewhere
            • #7
              Conrad, Do you have the gasket? I recently rebuilt my carb, a 2brl Rochester on top of a 4.3 GM V6 and I could tell by what I removed that the gasket was thick, when I got the new gasket it was a good 1/4 inch thick. No sealent needed and dont substitute auto gasket for marine. Donwon
              • #8
                Oh, so that's what the big hole is for.That makes sense - thanks scaaty
                Manitoba, Canada
                • #9
                  no just make sure you have the correct NEW gasket ,
