btodd1
- Dec 31, 1969
- 0
My boat started and ran for 10 minutes a couple times. I was getting it ready for the water and the horn was not working. I recently purchased this boat and it had sat for two years. I have gone though it. New deck and carpet. First day I got it the engine would not start but did turn over. I had to put a new coil and points. Then it was awesome. So, back to the horn. I pressed it and it sounded like a dying duck. I figured it was a bad ground so I checked and it was a bit loose. I tightened it and I tried the horn and it worked good and loud. I pressed it again and it went dead. I checked the battery and it was fine. The trim and trailor up switches worked fine. But when I turned on the key. I got no power. I wiggled the wires under the dash and it still did not work. I checked connections in the engine compartment. I wiggled some ground wires and it still did not work then, while working on something else, I turned the key and the engine started and ran fine again. OK, so I do some more clean up and rubbing compound on the body. Almost ready to put in the water! OK so i go to start and nothing. So I took a hot wire from the battery and touched it to the power side of the solenoid and it started right up. It ran for 1 minute then shut off. I noticed there was no more gas dripping into the carb. Then I felt the Purple/pink/ or purple/vilot/black wires going to a cylinder on the side of the carb and they are really hot. Then I start disconnecting the fuse block because I'm thinking it could be a short behind the dash. I figure I will re connect one at a time till I see if the carb wires get hot again. Later with the fuse block off, I turn the key and it revolves once and stops. No power to start again. Any help on and easy way to troubleshoot this or what to look for would be appreciated. Thanks!
