BajabossJD
- Jul 10, 2011
- 138
Hey guys,
Last weekend, I was cruising 1100rpm up the ICW and lost thrust. Prop fine.. Drained Drive oil (Looked good). Pulled the drive for the first time ever today and it looks like the Splines on the Yoke shaft were gone at first. After looking at it, the splines had almost a clay type material in there. I am sure its a combination of old grease and who knows what...
Does this look like broken down Aluminum from the coupler? You can see in the pics where I cleaned the splines out and they look pretty good now. Also, I see a missing O-ring on the shaft, and I did not see a gasket when I took the 6 nuts off and seperated the drive?!. Paper gasket?
Also, I took a pic of the bearing (again.. my first I/O drive service..had the boat 1 year). The bearing spins pretty smooth and their isn't play within the bearing. Also, U joint looks like crap..but moves freely and doesn't have any play from side to side (have no idea if that's good or bad)
Thoughts and tips at this point? Working on pulling the engine next.
Thanks,
Joe
Thanks,
Joe
