Sn# 1A338275
Boat (268 bryant) has 9 hours and has a blown motor supposedly from hydro lock. The Senario: I was coming into the dock after a 20 minute run where the boat rpm was varied from 2800 +/- to around 3800 - 4000 rpm. Slowed down through break wall and idled at 1000 rpm in a no wake zone to the dock. Along the way I shut the motor to talk to a friend and when I went to restart it was very sluggish turning over. When the motor caught it was followed by a loud knocking sound. It has been determined at this point to be a bent connecting rod as everything on the top end was o.k. The cylinder with the problem is # 7. Compression was 140 vs 175 in all other cylinders.
Merc is going to replace the block, but why this happened in the first place is more of a concern to me right now. I want to avoid this in the future. I have read a lot about the issue of hydrolock and don't think the wake against the back of the boat should/would have caused this as it was not an abrupt. Flappers? Manifolds? Engine timing?
When the new block comes the intake, manifolds, fuel system, pulley driven accessories will be swapped out. The mechanic is highly regarded, but I want to make sure I quiz him in the areas of concern. I don't want to be a pain in the ***, it was not his fault, but I am not the type to sit idle when there should be a reason for the issue.
Advice?
Advice?
