I have this 5.7L I've been working on for a few months now, fresh rebuild, I've ran a few tanks of gas through it now but it wasn't performing like I thought it should and it developed what sounds like a valve tick. Also....ever since the rebuild I haven't been getting any oil pressure on the gauge, but I hooked a manual one up and it was good so I figured sender was bad....not sure if that info is applicable. Anyways. I took the valve cover off and started the engine, I had the little oil clips on but it didn't take long for me to realize they were doing no good as oil was only lightly coming out of one of the rods. I also found that on an exhaust valve one of the spring rings at the top was broke off and making all the noise. Where should I start?
