I bought an 1984 sea ray 18'6" with a mercruiser 140 in it. Took it for a short water test seemed to run good. I installed a second battery and battery switch. Boat has new impellor. Took it out for a few hours and it ran good. Pulled into a dock and went in for dinner came back out and it would not start. It would fire then die as soon as you let prusseure off the key. It would stay running if you kept the key tuned toward the start position just shy of engaging the starter. Once in gear on this model the starter will not engage. This worked to limp back to dock on the other side of the lake. I say limp because the engine only had about half power and was missing.
I of course at the time assumed bad wiring or ignition switch but was confused why it ran so good earlier and just started acting up. Upone return to the dock and inspection the boat had about 5 gallons of water in the bildge. My thought is a leaking seal at the outdrive which seeped water into the bildge when sitting at the dock while we were at dinner. grounding out wires and causing (ground) and other electrical issues.
Anyone have anything similar or can suggest otehr theories to try and test or trace.
Going to hook the muffs up tomorrow and try to isolate the leak and see if it runs diferent "dried out" and on land.
