I have a problem with my 1988 alpha one/5.7 I have had problems with alignment since doing a complete restoration of a 1988 Celebrity 210v. Last season I was unable to get an alignment that wasn't off slightly to the left. the tool would go in with some effort and was harder to pull out. I did the best I could and the drive went on last year and it performed great for the last 3 months of the season. when I de-winterized it this spring, I started it up, engine ran great, but the gimbal bearing was whining, greased the bearing and it was silent again. started noticing a tapping sound at the rear of engine that became louder. I decided to change the gimbal bearing once and for all. after replacement, still misaligned slightly to the left, tool harder to put in, and now I noticed while my drive was off that there is a small leak of gear oil leaking around the universal joint. Don't know how to correct left alignment. all out of adjustment at elongated front engine mounts. I assume that there has been damage to the seal(s) and possible bearings in the drive due to misalignment. Boat is out of the water and is disabled during the best part of the season. Could benefit from some expert advice on where to go next.
