Well I have finally finished rebuilding my outdrive and was wondering.
When I put the boat in the water will there be a leak into the boat if any of the bellows isn't
fitted/sealed correctly ? Main concern is the drive shaft bellows. The shift shaft bellows will
be obvious and the exhaust bellows really doesn't matter (??). Will I have to pull the outdrive
afterwards to check any of them ?
Thanks for all your help..
Almost there...
OTG
Almost there...
OTG
