H20 Insane
- Jul 6, 2012
- 2
I dewinterized the boat (09' 175BR) about a month ago, ran it on the muffs and then took it to the river. It started and idles okay, but when I got to open water and started to apply power it would stumble pretty bad around 2k rpms. If I give it a little more gas it will get past the stumble and run great in the higher RPM's. I tried playing with the idle screw adjustment, but it made no difference.
Fast forward to yesterday and I get the boat out for trip #2 of the season with the intentions of fixing this stumble. I launched, let it idle and then got to open water. Same thing happens, so I go about doing larger changes on the idle screw with no results. Eventually the motor wont even start anymore without a good amount of throttle and it absolutely will not idle. I limp it back to the dock and bring it home.
Today I changed the Racor fuel water seperator filter, new AC plugs (gap at .045), set the idle screw to 1.54 turns out, cleaned the fuel filter at the carb inlet (tiny amount of debris) and entirely removed the filter at the fuel pump. Same thing.... idles good when cold, but as it heats up it does not want to run and becomes a bear to start (requires 1/2 throttle to get it fired and 1/4 throttle to keep it running). I think I've narrowed it down to the carb being gummed up. Or does anyone else have an opinion? Runs good til warm and then hits the wall.
I've got no issues rebuilding the carb, but if its a TKS issue and I can fix that without an entire carb rebuild then that would be ideal. Thx!
