Hello All,
This is a 1988 Wellcraft 21' with a chevy 5.7 or 350 motor with 260 hp. This is a re-manufactured engine from a manufacturer that was installed by me last summer. It has maybe 10 hours on it.
I was going to take the boat out in the bay to watch fireworks with the family last night. I was cleaning it out and the distributor got wet and it wouldn't fire. I dried it out and went to restart and the battery seemed low and not turning the motor as fast as it should. I hooked up a charger and let it charge a while. I tried to start and it started right up. I turned it off immediately because I had turned off the water to the muffs while I dried out the distributor.
I turned on the water and went to restart now all I get is a clicking noise in the circuit breaker, but the breaker is not tripped. I checked all the connection I could, battery terminals, I have 2 batteries. Wires to the starter as best I could and all the wires to the circuit breaker. I also checked the fuses behind the gauges in the cuddy cabin. This is so weird as it was running perfect before I turned it off. We take it out maybe once a month and I start it once a week on muffs for 15 minutes to keep things flowing. Better it happened on land and not on the water at night I guess, but disappointing none the less. We watched fireworks from land last night with the other land lubbers.
Anyone have any suggestion I can try? My brother is an aircraft mechanic and is coming over Saturday to help, but I would like to fix it before then if I can.
Thanks in advance,
Jim
Thanks in advance,
Jim
