starwriter
Banned
- Jun 3, 2012
- 42
I'm getting ready to start taking this boat apart to replace all 3 bellows.My first time.I haven't done nothing yet as we speak.First, question I have is the steps in removing the lower unit.I watched videos/utubes online.They make things look so simple.Example,To remove the 2 trim arms.First remove/pop off the caps.Well I tried that.I found my caps unscrew not pop off.Is why I'm here asking you all the steps & what else isn't in the videos.
I was told all you do to remove the lower unit it this,
(1)remove the prop.(2)Move throutle Lever all the way forward.(3) Remove caps from Trim arms.Then,remove lock nut.Then using a rubber hammer & a rod tap the long bolt out with out damaging threads.(4)Remove the 6 nuts & washers.After all of that 1- 4 above the lower unit & drive shaft should be ready to pull off.Is this correct?
Why I ask is because,some say to put throutle forward.Others say remove a pin if you have one.Here we go again,If I have a pin?Do I have a pin keeping the lower unit from pulling off or not?How to I know?Where would this pin be located if so?What kind of pin are we talking about if so?
Next question,
To remove the Trim housing to replace the bellows.Requires a tool to remove the two trim bolts.I was told it's a 12 point star or allen.What size star or allen is the tool I need?I was thinking of going to a auto parts store to see if I can get this 12 point star tool or allen.I was told those two bolts are the hardest to remove.
I see many utube videos of removing the lower unit.Not one showing you how to install the lower unit & drive shaft.
Funny thing is I haven't even started this project yet.I have a feeling I'm gonna regret it as well.From what all I hear & see from utube videos.I've been looking at my boat on the trailor for 3 weeks now regreting in starting this project and the 90-100 degree heat.From what I hear shops charge over $1000.00 to do this job.Why this system was ever designed this way is beyond me.For a part/bellows that is required to be replaced every 4-6 yrs.Replacing a engine & tranny in a car sounds easier then a simple rubber boots on a boat.That's like the same on a drive axle boot.My serial# off my sterndrive is 00405065 (184R) OD357324 any tips & information would help?Can someone find me a part number & brand for a complete bellows kit with this numbers I have?Thanks.Dan.
Next question,
