james_dorion
- Jun 7, 2012
- 18
hi again everyone; Mercruiser 165hp model number 21653 serial number 3465185. i think its a prealpha drive? I got towed in the other day. I had the boat running very well for the morning fishing with no problems. Then when on return home and engaging the trottle into forward position the drive made a grinding sound but still was somewhat in forward gear. I changed to reverse thinking seaweed (although i knew there wasnt any) then back to forward with the same outcome. I checked the linkages and all seemed well. Upon wiggling the shift cale and other parts of linkage, the gear makes no attempt for forward now and no grinding. When i jumped in the water to turn the propeller counter clockwise while the throttle was in forward gear. The propeller did turn with resistance and clicked in the counter clock wise rotation. The reverse also turned both directions with little force clockwise and a clicking counter clockwise. In neutral it spins both ways with no resistance. All switches seem to be working fine and now that ti is in the driveway it still does the same thing. Any pictures videos diagrams info and assisstance is greatly appreciated.
