waterdawg60
- Jun 21, 2011
- 11
I put the boat in the water today and discovered one of the bolt holes holding down the thermostat in my 350 chev is stripped. Should I retap the hole or put a spring in it. I have never tapped a hole before but think i should be able to do it (i have a cheap tap and die set) but are the springs ok to use. I need the boat in 2 days..... :-O.
