Jay Curtis
- Mar 7, 2011
- 34
i have a 1980 228 Mercruser SN 5765260
is this OD considered a pre Alpha OD the chiltons says it is a Model 1 or I or does that mean Alpha 1
i need to adjust or replace the lower shift cable and i find all different instructions on the setting of the lower shift cable my Chiltons says 6.25"
i saw a video by Chris iboat member that says 6" for Alpha 1
i saw instructions from a parts supplier that satd to set the length at where ever the shifter is when the od is in forward
my problem is that my spark interupter switch is not working or at least not working at the proper time to let the drive go into neutral
thanks for the help
thanks for the help
